First off a little background on the car, well I guess read the signature. I am running the Maft-pro in speed density. I turned up the boost using the elctronic boost controller on the Maft from the stock wastegate pressure on the 20g being 10psi to 12psi, everything was fine. I then went up 2 more to 14psi. After the run I immediately felt a loss of power and my afr's went to about 12-13. So I tried to boost just a little to make positive pressure and only got to about 1-2psi and I could hear the boost leak through the window. So I immediately pulled over, upon doing so I put the clutch in and then the power steering went out, look down, rpm's at 0, great! I try to start the car again and nothing, the only way I could get it to start was to get on the pedal a little and when I did the afr's were still rich. Let off the gas and it dies.
So issue is that I have a boost leak. I dont have anything to test for a boost leak, so I am trying to narrow it down by going off the idle symptom. I want some help with my reasoning before I go tearing down the intake.
I am thinking that I have a leak on the engine side of the throttlebody, meaning like a manifold gasket or something. I did get it to idle this morning, I am guessing because it was cold though, my vaccum was around -8 where it is typically around -18 or -19 and it is running rich still. Can anyone confirm what I am thinking? It just doesn't seem like it would be on the intake piping anywhere with the idle issue I am having. Thanks for the help.
