Turn signal problem
Pride
25
Idaho Falls
okay so im not too car technical but i took apart my cluster to see if my speedo cable was unplugged and when i put it all back together i noticed that my turn signals stopped working. they worked before but now there not. i checked the fuze and it looked good. my lights still turn on and everything its just the turn signals that dont work. no noise or anything. if anyone could help that would be greatly appreciated. thanks
dubsupra209
CENCAL SUPRAS
Mar 6, 2009
1,810
Merced, CA
i did the samething and had the same problem but the other night they worked. In my friends 5.0 when its hot or he dont cover it his doesnt work either so i was thinking that could be my problem to so when i cover it it works idk im not really worried about it though i have rods knocking anyways...
casgallo
Not a lurker :)
Apr 3, 2005
68
New York
easy as cake fix. go outside to your car and plug in the 4 way switch and your signals should work fine. either way report back :)
bowb4mymk3
Antelope Valley
om my B and i checked the hazard swith and its plugged in... so some more info... when i was leaving the drive i went to turn right my signal flash ONCE and then it hasn't worked since. i think i was hearing an electric short sound. anyone had this problem before?? im having some interior electrical issues right now :(
isnms
United States of America
Oklahoma
i80.photobucket.com
pull off your center trim. two crews in the ash tray and one on the driver side at the back. the just pull it from the dash and kind of up and out at back of gear shift.
(manual, i don't know if auto has any more steps.)
