turbos?
allen600
166
oakdale
i was wondering what turbos there are to run with a t4 flange and if anyone has a current set up they could post pics of i have the manifold just trying to figure out what turbo to run
Moy
It's broken...
Aug 6, 2008
2,432
Beach Park, IL
Uhhhhhh there are a LOT of turbos with T4 hotside inlets.... what are your power goals, what will the car be used for, what do you have done to your engine, how much money do you have to play with?
allen600
166
oakdale
im lookin for high 300's or low 400's for horsepower, its just my daily driver, forged rods and piston, 3mm metal hg, brian crower valve springs, lexus afm. im not trying to spend alot less then 500 if its possible
bloodasp90
JZwhore of JAPAN
Nov 9, 2007
529
on the river
not a whole lot of T4 for 500, its worth the money to try to save more and to get a turbo that you know that will last and not some cheep ebay junk.
i my self am working on a holset T4 set up, so thats a route you very well can travel, but its a little more then 500..
allen600
166
oakdale
yeah i bought that ebay manifold but its flanged for a t4 i would run a holset hy35,hx35, or even a hx40 but i believe there t3 flanged
Can get a adapter cheap and holsets are cheap all day long on ebay and there cheap to rebuild.
Best bang for the buck except exhaust will need to be changed and custom oil lines, coolant lines if it has it, and maybe even custom ic pipes. Plus you need the fuel pump and injector esp with the lex and you would also need tuning.
Cant just up the boost. Thats usually the last part.
Blackdawg
Taco Soup..my rides
Oct 12, 2010
247
Wyoming
Check out Aarons turbos on Driftomotion man. I bet the 60-1 turbo would fit you good. all garret internals too so they are much better then an ebay turbo. im going to run the 67mm one myself
Skeezix
Supradope
Dec 30, 2009
229
Regina, SK
+1 I was thinking of sending them my old CT26 for the 57 trim upgrade
