Turboing a 7MGE
RIPDOTCOM
157
Tallahassee, FL
In order to add a turbo to a 7MGE I assume the basic setup would be the following
Turbo manifold
Oil lines
Turbo
FMU
Timing retard or 7MGTE ECU
How much boost can the 7MGE engine handle. I was thinking about putting together an 8 Psi setup. Is the stock fuel pump the same on a NA vs. Turbo supra?
Allan_MA70
1,055
Melbourne, Australia
the rods, crank and pistons are the same (but higher compression pistons)
if i was you id get an aftermarket ECU, bosch motorsport fuel pump, GTE injectors (or better), turbo, manifold, braided teflon turbo oil lines, intercooler and you will be plesently supprised how much power you make!
