turbo
Stock turbo everything.
Other than that dm sells a kit for 1500. But you will still need gte Ecu harness cps coil pack and igniter.
TheBlueSupra
82
Idaho
Cheap and turbo kit go together like fire and getting burned. Like hvyman said, stock everything from a turbo car and replace what needs it with new parts. It will not be cheap.
chrisisg77
169
los angeles
CHEAP and SUPRA should'nt belong in the same sentence. Might aswell get a GTE. I got LUCKY and got a really good deal on a GTE just had a bhg of course. I paid 350 for just the motor and Turbo (very little shaft play) and a couple of things. Then in the proccess of the swap i had to buy little parts here and there for example ARPs, oil cooler, downpipe, coils, harness etc. I spent in total around 1300 on just the swap. Thats because i got a good deal on it . Be ready to spend up to 2k and maybe even more. I suggest saving up and do it right the first time so you wont have to do it later again another time.
