Hey everyone,
Im sure this has been posted before (maybe even beat to death) but i did a quick search and didnt come up with the answer i was looking for.
Im looking to see what the best option for a mild turbo upgrade is. Something that is not CT26 based (because they are prone to cracking in the turbine housing), and i would like to be able to fit it up with minimal upgrades.
Here is the setup i am planning to run. I have most of this stuff already.
-Stock 7m internals, OEM HG with ARP studs torqued to the higher then OEM spec (like 70-75ft lb or whatever)
- mkIV 550cc injectors (and rail if it will fit)
- aeromotive adjustable fuel pressure regulator with -6an line to rail
- walboro 255lph pump
- Greddy Emanage blue
- Lexus AFM
- 3" exhaust from turbo back with no cats
- wideband o2 seonsor
- EVC boost controller
- greddy turbo timer
- fmic
Now first off, dont say "just put in a 1jz" or anything like that. I already have a 1JZ with a R154 and a T78 turbo. Its already destined for a transplant into the car, but i have some work to do with it first.
Im just looking for a decent turbo to run in the car with its current 7m and auto transmission. Want something responsive, that will make more power, blah blah.
Any help will be appreciated.
thanks
- Lexus AFM
- fmic
thanks
