Turbo Upgrade and Manifold Question
Deathseeker31
Getaway Driver
SOCAL
I looked around to see if i could find the answer to this question but no luck. Would a 2jz manifold mate up to the 7M head? The initial assumption is no, but i wanted to make sure as I have someone that is giving me a 2jz tubular manifold and i was wondering if i could use it.
Also another question i have is would a t70 turbo be at all compatible with the 7M? It has a vband 3 inch outlet, .70 A/R... Oil cooled. the stamp on the cold side says M24, not sure what that means. has anyone used this turbo? how does it perform on a 7M any help would be greatly appreciate it.
here's a picture:
picture.php
Ricky L
MKIIINA
Destroyer of Turbos
Plano, TX
no the manifold will not work without some cutting and welding.
that turbo will work but you will need a compatible exhaust manifold and a custom made downpipe thats v-band
FullNelson
574
Coastal Georgia
The manifolds can be had for around the $200 range. That turbo would be alot of power and you wont see any of its potential untill your at or above highway speeds to get it to both spool and not make your tires smell funny.
