C
Chaz
Guest
I just got back from the exhaust shop. It was my first run with the new turbo (new to me) installed. I did two WOT runs from two thousand RPMS in third gear. It produced very little boost until about 3000 rpms and built up to around 11 or so lbs at 3800 rpms, which seemed too little to me. Then it went crazy. Between 3800 and 4200 rpms, the boost shot to 21 lbs and when I let off the boost guage read 23 lbs (like the BOV was delayed), which was way too much! I drove normal for the next thirty minutes until I got to the muffler shop. I raised the hood and found the turbo to be very hot (Duh). I mean VERY HOT. Even after an hour, it was still to hot to put your hand on for more than a few seconds. Now this may be normal. I don't know. I've never messed with turbos much. But I don't know how the boost would hit 23 lbs with a yellow spring (11-17 lbs) in the wastegate and the adjustment all the way out (spring with the least pressure applied).
When cold, the turbo shaft had no play in it, but I did notice a small amount of play in it when it was hot. I'm thinking that may be OK on a hot engine. I backed off the blow off adjustment to soften it up, but didn't notice any change on the drive back. The turbo makes zero noise and spins freely at an idle for a few minutes until slowly coming to a stop, then picks up as soon as you touch the throttle.
Could this be a wastegate problem and how do I check.
I have:
Trust Greddy t78 33d with greddy 40 mm(I think) wastegate (yellow spring).
Greddy Profec B spec 2 boost controller
Apexi SAFC, 2JZ Map, All exhust piping heat wraped down to the bottom of the down pipe, Turbo blanket
ANY HELP?
I have:
ANY HELP?
