Turbo Timer Help
JNasty
i drive fast cars (supra)
Jun 25, 2005
358
Jacksonville fl
hey i just gor a plug and play for my turbo timer (greddy full auto timer) but the wires on my timer are cut so what i need is for some one to tell me what wires go to what at the bottom is pics
I KNOW WHERE THE THICK RED BLUS AND GREEN GO
drunk_medic
7Ms are for Cressidas
Woodstock, GA
http://www.greddy.com/tech/FATURBO_TIMER.pdf
Go here. You will need Adobe Acrobat Reader to read the file.
This will tell you what wires need to go to where. Then, you need to look at your car's wiring manual to see what corresponds where.
My advice: if you tap into a wire that goes to the ECU, tap into the wire 6" to 1' away from any plug if possible.
isnms
United States of America
Oklahoma
i80.photobucket.com
see if this helps
notice this is for an hks. your wire colors will be different. consult the tewd for the ignition harness pinout and find out what color wire goes to what signal.
edit: don't connect the blue acc line and the stock alarm will arm.
