turbo timer help.hooking one up
7mgtesupra
28
tampa,florida
i need to know how to hook up a turbo timer on my 88supra.its a hks turbo timer.someone said that i dont need it .but it cant hurt to hook up right.
marlonvip
Supra -only way to fly
Sep 2, 2006
189
Denmark
do you have the p&p harness?
supraracer49
3rd Gen Life
Nov 20, 2006
333
WNC
Harness would be best. I have a greddy one and just took a test light to the igniton wires and turned the key to check which wires are which (12v constant, acc, ign.). If you hook it up and it doesn't work you are connected to the wrong ign. wire. There are 2 ign. wires and only one of them will work you timer. Hope this helps
JAB89
68
Atlanta, GA
isnms said:
^Yes
Get the harness:
HKS Turbo Timer Harness for 1987-90 Supra Turbo
ITEM # HK 4103-RT001
$15.00
http://www.supramania.com/forums/showthread.php?t=11453
Absolutely, get the harness!
Note the tip in isnms's link, about disconnecting the acc line (blue).
Look here to see why:
http://www.supras.com/06/techcenter/display.php?QID=48
(I didn't cut the wire, just poped it out of the connector and shrink wrapped it)
Also, you can download Installation and Users Manuals form HKS here:
http://www.hksusa.com/faq/?ID=1647
You will need to know which Timer Type you have so look here:
http://www.hksusa.com/categories/?id=1091
