Ok, most of the wire is connected correctly when I got it installed for free. I found the two wire for the factory alarm, is the two wire coming out of aftermarket also connect to both the factory arm/disarm and the powerlock? Right now I have the aftermarket connect to the powerlock and I splice the two wire into the factory arm/disarm also. Ofcourse when I finish I sat in the car, lock the door and unlock the door the alarm doesn't go off like it suppose to. Oh and on the right side of the steering column I found a wire harness that have two wire connect to the ignition switch i think but the other end isn't connected to anything. I think it suppose to connect to something but not sure where.
I also arm the alarm with remote and unlock from in side and the alarm doesn't go off either. I am not sure if this is how it suppose to be or not. I didn't splice the wire, I use the T-splice cap and pinch the wire i.
Right now I don't have a TT yet, so I am not sure it that is also contributing to this
. Which is better, a Greddy full auto or an HKS type-1 which is also full auto. I think they have about the same feature but not sure about durability and ease of use.
