Turbo questions
Status
Not open for further replies.
Kindred94
15
fremont, Oh
I just bought a 89 7mge thats gonna need a good build to bring it back to life. I know im gonna have to tear the engine apart and check over everything so ive been debating on putting a turbo on it now or wait because i plan on putting a 2j in the car in the future so idk weather if I should just hold off or not. So i wanna know your guys input on that situation and also what turbo would you recommend for either? Its gonna be a big single and when I put the 2j in it ill be looking for heavy hp. Thanks.
If you put a big turbo on a ge without a standalone it's not going to last very long.
My opinion if the ge runs good just drive it as is until you swap. No point really to mod it all if your just going to swap.
Kindred94
15
fremont, Oh
right on. Im just antsy to turbo a car to be honest lol the 2j is gonna be awhile and im also gonna do alot of research about the swap before I jump into it. I shouldnt have said big torbo for the 7m obviously thats for the 2j. Still would like inputs for either engines though.
Dan_Gyoba
Turbo Swapper
Aug 9, 2007
1,836
Alberta
www.gyoba.com
Do not put money into anything that you plan on replacing later. Any cash spent that way is purely wasted. I follow this philosophy for about everything. Even if you bargain hunt for everything that you put into rebuilding the GE (And/or swap a 7M-GTE in) you won't get the money back out when you pull the engine.
If you're going to fix the 7M-GE so that you can drive it, then do so, though if it needs a rebuild, and you really want to drive it first, then I strongly suggest that you find a decent running engine, or at least one that doesn't need anything on the bottom end. If you MUST swap out the HG, just do a Toyota OEM HG, and don't do anything to the bottom end. There should be no shortage of donor engines for this kind of project. Don't put any forced aspiration on it, just drive it.
I drove an '89 NA for 14 years, and it was a very nice car to drive. Not super fast, but enough to put a smile on my face when I wanted to open it up.
I'd have considered a stock CT-26 on the 7M-GE at stock boost levels to be okay, but I wasn't going to do that without a good fresh, solid block to start from, and it was easier to swap in a 7M-GTE instead, so I did.
I'm doing a ground-up rebuild of a 7M-GTE, and when I'm done I'll have spent about what I would have for the longblock for a 2JZ-GTE. I'll have a known good build to work from and little to worry about. I also have plenty of options for used parts, since it's all stuff that the car came with from the dealerships here. For the money spent, I'll have more power than the 2JZ would have put out even after spending more money on the single turbo conversion.
Kindred94
15
fremont, Oh
The previous owner had a bhg but rebuild The head I guess so I wanna pull the engine and check over it then run the car for a little while to make sure everything else on the car is solid before I do the 2j swap on it. He said the car sat for like 6 years he just doesn't have the time anymore to put everything back together besides the motor.
te72
Classifieds Moderator
6,616
9
WHYoming
IJ.;1848277 said:
Ditto, set a goal and achive it, too many half assed build here fail after someone does something 3 different ways due to not sticking to a plan..
Made bold for emphasis. Been there, done that, you'll be way better off just focusing your attention and learning how to be patient. See that "living with a Supra" link in my sig? Read that. ;)
Another MkIII
697
Chicago
Patience is the most imprortant part of owning a Supra. I have owned mine for almost 3 1/2 years. I have put less than 1000 miles on it...
-AM3
91Supra313
1,062
Clarksville TN
Glad to see another one saved....But the main question is what is wrong with the motor that is making you want to rebuild it? Is there a BHG? Bad rod knock? I read your OP 2 times now, and can't figure out what is wrong with the motor. Maybe I missed it thanks to these painkillers, but in my eyes, and I think 99% of the group will agree....If it ain't broke don't f*ck with it. That is a sure fire way to mess something up and end up spending whatever you planned on using for that 2J swap ( which by the way I am starting this weekend ) and spending it on a motor that you don't plan on keeping. If it runs, and doesn't overheat....leave it alone.
The 2J swap is going to cost me around 3,000. I swapped a friend my built 7M for this 2J. So that cost is purely parts to get the swap done. If you don't have access to the free motor like I did, count on at least 5,000. That is also just you doing all of it. Drift Motion quoted me at $5500 to do the swap. That was with them sourcing everything. I would just have to fork over a grand for shipping each way. Good luck and keep it in the pants.....The cash that is.
Kindred94
15
fremont, Oh
Thanks for all the input guys very much appreciated! The reason why I wanna pull the engine is because when the guy replaced the head gasket 6 years ago all he did was place the engine back then let it sit it hasn't been started or run since then so I kinda want to go back through it and make sure everything was done right before I finish up putting everything back into the engine bay. I can post a pic of the engine bay later on today when I get on my home computer you can see what I'm dealing with.
Status
