turbo pressure sensor
lintlars
ROOTS RADICALS
Ft.St.John BC
Im in the middle of putting my engine bay back together, does the turbo pressure do anything other than send a signal to the stock boost guage?Im trying to clean up the engine bay a bit everything that does not need to be there is going.
Thanks
koulee
497
Its probably sending a signal to the ecu telling it how much boost is being built up...
lagged
1991 1JZ
new rochelle
seriously, dont post if you DONT KNOW!
misinformation is the killer of all internet forums. do you want to kill supramania?
there should be a new rule, if a user posts something completely incorrect 3 times he should be set to read only.
May 19, 2006
209
SE Wisconsin
good rule
lagged
1991 1JZ
new rochelle
88YotaTurbo said:
so in other words if you have an after market gauge you don't need the sensor???
yeah but then youll have a non functioning guage in your cluster. you can replace the stock boost gauge with the volt meter from an NA cluster.
SupraDreamPDR
Boost-a-holic!!
Feb 3, 2006
1,140
Springfield, OH.
thats what i am doing. installed aftermarket boost gauge (stock on is slow), removed the sensor for the stock gauge and am gonna install a stock voltmeter from an NA Supra.
