well i thought i would post on this forum since no one would answer on i-supra. well quick question, i would like to put a turbo on my 7m-ge. i know i know it sounds stupid, but for me its alrite. i just don't want to replace my good running lower mile motor. my GE has 93,000 miles on it and has just had every gasket on the engine replace (including HG) and the head has been shaved and the cams polished. this is why i don't want a jumky used engine. oh and the bottom end looked perfect. well on to the question.
1.what electronics would i have to use?
2.would i need a turbo ecu?
3. would i need to change the intake manifold and T.B. over to a turbo one?
4.would it be easier to go standalone?
5.i know how to run a turbo oil return line just not a feed, need help with that??
and if you have any other ELECTRICAL info for me let me know. other than that i know what else i need to go turbo on it. yes, i know that with my high compression pistons it wouldn't be a good idea to go over stock boost (6.5psi). i will rebuild in time to lower compression pistons later just want to get a turbo on it for now. and yes i know the tranny is weak, will also be replaced.
thanks for the help
thanks for the help
