Can I just make the gaskets for the oil return tube from turbo to tube and from block to tube? Ive called everwhere around me no body has them i have a gasket making kit.
bluepearl said:factory toyota has what you need. I bought them there. Fix it once, fix it right. That's not the place to take short cuts. IMHO
PIONEER said:what is the world coming to. Spend $2 and get the proper gasket from Toyota before you start a oil fire in the car.
Whats next? Using rubber band to hold the wastegate flapper shut so you can get more boost?
