for the guys that have removed the return line before, can it be done with the turbo on the car?
seems the solid return from the turbo to the end of the oem connector at the block is joined with a small section of hose and hose clamps. I found one clamp dangling and more oil to add to my clean up efforts. Unfortunately the hose/connector is a bit to big I.D. and the pipe coming off the turbo is not sealing 100%
option
A) new braided ss line from driftmotion
B) put a smaller connector between the two pipes,
i hate to remove more then i need to to get to the bolts on the block and what not, any tips?
option
