Ok, just put a new ct 26 on my 90'. First time I've done a turbo removal/install. (yes I did all of the priming) After idling for 5min checking for leaks I found it leaking oil out of the oil pipe where it comes off the turbo. It had a new gasket on it. It was torqued per tsrm. Should I still use some permatex or something like it to seal it better? The tsrm doesnt call for it. It was leaking pretty bad. I removed the turbo to repair. I also ordered a softline kit. If anything the softline is bound to make the install a little easier and flow better I hope. any thoughts?
