Turbo oil drain port needs to be blocked off, need suggestions.
toyota.s
Long story short; rebuilding GE, machinist says blocked cracked. Machinist has GTE block in stock, he makes sure it's eligible, it is. I buy block. Fast forward, engine is almost assembled.
I just want to know any suggestions to block off turbo oil drain back port? GE block doesn't have that port.
First thought is buy an oil drain flange with AN -10 fitting and just cap it off with flare cap AN -10. I do not plan on adding turbocharger, not even down the road. Just a cruiser at this point.
Bru
77
Tampa Bay Area
If you still have your old block, borrow the block off plate that's under the oil filter. Test fit the one you have that I saw in your other posting. Otherwise, you should be able to cook up a block off plate cutting one from aluminum. Make a paper template that fits or get the gasket (15473-41010) that goes with this connection. The 2 nuts are 90179-08012. You can seal it using Permatex ultra-black silicone. It's extremely oil resistant and is my go to sealant. Walmart has the cheapest price. Product number is: 75190. It's the same formulation as the more expensive 82180. I found this out after calling Permatex. Evidently, 75190 is only sold at Walmart like a house brand.
