turbo oil drain line question
89turboguy
196
Denver, Colorado
i was searching and i saw that the oil drain from the turbo is mainly gravity drained. and since i made my own block fitting the drain hose hangs lower than the block fitting. since it is gravity drained will this cause a problem?
souprat
fairfax VA
you could try summit. we're not talking about the stock drain right? why dont you just get a shorter hose that does not hang below the drain into the block?
89turboguy
196
Denver, Colorado
we are talking about a -10 an drain fitting not stock. i have the ss oil line, and with the way i made my drain fitting it just makes it too long so it hangs below the drain. so it would cost more to get a new hose than to get a drain fitting. so does summit carry the drain fitting at the block?
