Finally got everything put back together after replacing a couple of bad injectors. Started it up, and i couldn't have been happier....
but I don't seem to be getting any boost. vac at idle is about -2, which seems about right. when I rev it up, gauge goes to -4 (max), and never goes up. It won't go into positive.
I checked the turbo, when it runs (without the intake piping on), the turbine spins, so i know it's not locked up, or something. I "tested" the pressure sensor, by blowing into it, and I was able to get it to show to 8psi (maxed it out). if i varied how hard I blew, the gauge did go up and down (no, homo).
checked, and double checked all the vacuum and intake lines, no leaks anywhere.
any idea why I am not getting any pressure?
not sure what else I need to check...
