Turbo manifold thoughts.
suprafredde
160
South of sweden
99% sure that Im going GT35R
Id like a SS321 manifold but the ones that I have found has the exhaust split up 1-3 4-6. The exhaust housing on the GT35 is a T4 undevided.
Does this matter? Heard that you shouldnt do the opposite because the separating wall in the exhaust housing gets so damn hot it can crack.
There are a few manifolds on ebay but who should I buy from? Maybe you can give me a name with good rep. (That ships to europe)
Also my friend is looking for a mani for his 2J GTE. A divided one, seems hard to find. Need help with this too.
suprafredde
I know of another manifold...
(if promoting his products in any way will get me in trouble, please edit or delete this post)
jdub
Feb 10, 2006
10,730
Valley of the Sun
That manifold requires relocation of the charcoal canister to install an external wastegate...not a big deal. I'm also pretty sure you can't use the stock oil return on the block...the manifold tubing is in the way. Welding a -10 AN bung on the pan will fix that.
jdub
Feb 10, 2006
10,730
Valley of the Sun
Ahhh...thanks for that Justin. I'm considering getting one of these. Is the wastegate still in the same place as the pic?
MassSupra89
Almost done.
Nov 3, 2005
1,707
MA
I've got that manifold but have yet to mount it up. Bought it about 6 weeks ago. I knew about the return line and planned on tapping the pan but I'm not sure if I got one of the "new designs". This is the first I heard of that.
Justin727
T-virus infected
Yes he made about 3 different batches to get it right. the newest batch is suppose to clear the filter housing and use stock return line.
it has bars welded from the turbo flange to head flange so its braced. It started life out as a 1j/2j manifold design. I would like someone to chime in with a current purchase and fitting. I need to get back in touch with zoon and see how he's been.
MassSupra89
Almost done.
Nov 3, 2005
1,707
MA
Mines got the plates welded to the turbo flange, any differences in the runners style to tell which version I have? Engine's at the machine shop and I have nothing to referance from. And Zoon isn't the greatest at returning e-mails promptly.... or ever.
