turbo manifold smoking
JP85MX73
79
NY
After revving the engine im getting some smoke coming up from the rear turbo... what you guys think? Turbo seal? Manifold gasket?
JP85MX73
79
NY
I can't tell right now as im waiting on a dp gasket but there is a significant heat and air coming out from the manifold area could just be dp or manifold not sure yet. What other symptoms could i look for?
JP85MX73
79
NY
Car seemed to run ok. But i can't tell how much im boosting wihout a gauge. But just going by sound and feel it seems like im boosting ok, possible cam gasket leak maybe?
92TealSupra
Supramania's Parts Man
Sep 2, 2008
1,584
Great Lakes State
Did you just put this car together? I have seen that when you put it together oils may get on the manifold and cause smoke, if not then you may be leaking from somewhere.
te72
Classifieds Moderator
6,619
9
WHYoming
Mine smoked like a bastard for a bit after first getting it going, but it was mostly assembly oil and the fact it hadn't been run in quite a while. Smelled bad too. I know that rear turbo is a bitch to get at the manifold nuts, but try tightening them up, sometimes they come loose.
JP85MX73
79
NY
I did just put the car together, but i had ran it several times before.. and it did smoke a few of the other times :( so i think its gotta be a leak.. Im gunna finalize the wiring today and try to position my radiator then let it burn off some crap... fingers crossed.. i dont even think i could get to the rear manifold if i wanted to LOl Wish i had the money for a single:nono::nono:
te72
6,619
9
WHYoming
Oh, it's possible to get to the nuts for that rear turbo's manifold... have fun is all I can say. I'll never replace a y-pipe while in car ever again. :p
