Just wondering if anyone has any help hints or tidbits on removing and installing the factory turbo. I have only had to do this a few times now and every time its been a pain in the ass.
Michael
take all the accessory crap off... afm accordian hose filter ic piping that runs over the top of the turbo...
then take the heatshield off...then the dp and remove the dp completely makes things easier....then remove the ic pipe off the turbo so you dont rip it later on.... then remove the oil feed line bolt and then the oil drain nuts underneath.....then the 4 nuts holding the turbo to the manifold....then pull straight out and then rotate it and pull up.....
i can get one off in about 15 minutes if none of the bolts are a pain in the ass with rust and shit.
