Turbo Hot Pipe
dumbo
1,911
Albera, Too Far North
Ok I have a ETS intercooler kit, but it still uses the stock 'Turbo cast Elbow'.
I went NA-T and have never even seen this elbow. I made a solid peice out of 1 7/8"(which is the CT-26 outlet size i think) but had to use crush bends, it works but...
has anyone got a nice single peice the've use?? Or there solution.thanks, and pics if anyone know what i'm talking about.
dumbo
1,911
tbcmorris;1214739 said:
im not sure maybe some pics of said piece?
http://www.ma70.com/bishop92t/techtips/ma70undercarriage.jpg
i'm pretty sure its that one, but like i said, my supra is the only one i've looked at underther hood.
is the stock one good for moderate mods with abbout 13psi? is it free flowing maybe i'll just get a ussed stocker.
is there afterarket ones to replace the stocker???
tbcmorris
SM Expert Thread Derailer
Mar 14, 2007
1,820
PRUVEN PERFORMANCE MILFORD CT
are you referring to the pipe on the inside of the fender? that will definitely flow 13psi.
or are you talking about the turbo elbow....if this they suck get a bic downpipe
im not quite following exactly what you referring to.
dumbo
1,911
the pipe beside the lower rad hose. my intercooler kit had all new pipes including '3000'pipe, but not the one from the turbo to intercooler.(well most of it anyways) i need the elbow to turbo. hope that helps.
tbcmorris
Mar 14, 2007
1,820
ok i gotcha now...unless you wanna replace that whole setup from turbo to intercooler leave...it will handle 13 psi if your goals get more ambitious ditch it.
and you need to purchase that elbow. ill look in my garage tonight. i believe from parting out i ended up with an extra one.
Oh, that horrible cast elbow that's a major restriction? ETS kit should have had a pipe to replace all of that...
dumbo
1,911
yah it is cast aluminum right? and nope, i was a bit po'd that i bought that kit cause i thought it was 100% nope it litterly ends at that elbow, instructions said i had to unbolt it and spin it or somthing, but not having one(and the other one or two? pipes to the turbo), it went custom from there.
But the peice I have in there now is maybe worse than the stock, still pulls good but I want to do it right, then build some caps and pressure test from TB to Turbo inlet to 20psi, and be done worring about that.
So what are the soloutions?
frontierguy25
968
TX
Do you know some one that can weld aluminum? What you can do is buy a U pipe for about $25 then cut it into thirds where you have 1 90 and 2 45's then position it once they are cut to fit up to the pipe off the ETS kit. That is what I had to do for mine.
Or you can just buy 2 45* pipes and cut them to fit up and then take them to some one to weld them together or just put a coupler on them. You will need a 2-2.5" coupler off the turbo for the pipe.
dumbo
1,911
that sounds good, i guess i'll fab her up myself(with patience lol)..i was just hoping i could by a replacement.
so you went that route because that stock elbow is restrictive??
got an pics you'd like to show, my cars in vancouver and i'm not:cry: i only go down for a coupe weeks at a time and i try to mod/tune/drive as much s possible.
dumbo
1,911
ok now were talking, good stuff poodles!! its a lil pricy but time is of the essense.
that is for the stock IC, but judging by the link i posted earlier it is close to the same inlet posistion as the ETS IC.(Going of memory and a few pics a took of my car)
I like the look of this, ALOT. Any input please.
Anyone used this pipe before?? Is this a reliable site?
frontierguy25
968
TX
Seriously, go buy 2 45* 2.5" pipes and cut them, they are aluminum so they cut like butter with saw. Buy the reducer coupler for the turbo and one other coupler if you don't want to have it welded. It would take you a whole 30 minutes to do it. I'll even PM you my number if you want step by step help.
That pipe is hella expensive for what you get. Just spend the $60 on what I told you to buy and be done!
dumbo
1,911
true...but i know that by the time I f around and fit it, then go and get it welded and put back together, it'll be half a day. I also gotta change my cams/valvle covers and throttle linkage, and install a short shifter. then tune haha. 2 weeks dont last long:cry: its worth 60 bucks to me.
thanks for the help though
i did think there would be many of these pipes
EDIT: i do find the "2 psi increase in boost pressure" a bit of crock though.
