Turbo hookup
Emik87t
GameOver
May 30, 2007
213
Iowa
Hey quick ?, where do all these lines and fittings go, i know where the lines go on the turbo, but where do they run to, and the fittings.
MKIIINA
Destroyer of Turbos
Plano, TX
looks like an sp turbo there.... the lines with the blue and red collars are coolant lines. the smaller one with silver fittings is your oil feed line.
if that is indeed an sp turbo the rubber hose (cheap!) is part of the oil return line. you can also get a -10 line made for the return that wont leak ever (those worm clamps are a pita to do on the car)
Emik87t
GameOver
May 30, 2007
213
Iowa
ya i had one on my old turbo, that had an adapter to the block with threads instead of the pipe, and it was a bitch to get on and off but it was nice. i still have it though. I know where everything hooks up to the turbo to, im just not 100% sure about where they hook up to.
