Turbo Clamp
Mrbaboon
277
Victoria, BC
LOL, you're probably better off going and buying a used turbo for the amount the dealer is going to charge you for that.
And yes, you're gonna have to go visit Toyota. Give Champion a call and see what they can do with you, but you really should lube up regardless.
SupraStorm1080
IT'S A LIVE!!!
Apr 19, 2006
78
riverside, SO cal
If i try to drive the car do you think the turbo will split in half??? Hey anyone have any ideas on how to fix it??? i just broke the bolts off but the clamp it self is still in good shape so you tink i can drill a hole through and use a new screw and nut???
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
I could picture the exhaust side slipping down and catching the blade while spinning at 100K RPM and shredding the turbo instantly, not the mention the metal pieces bombarding the engine bay...
xanatos
63
Norcross, GA
Actually, going back and looking at it again, it does state that it's a vband clamp for a turbo housing. Perhaps someone should measure and see if 3 inches will cover fitting the housing on the CT?
supra87t/t4
Phase Two
Apr 9, 2005
219
MPLS, MN
I have a clamp from a broken turbo that I took off last weekend, I can send it to you if you want. Toyota wouldn't even sell you just the clamp, you'd have to buy a whole turbo. I'm sure there are plenty of people with broken CT26's out there that could get you a clamp.
xanatos
63
Norcross, GA
starscream5000 said:
I believe they are talking about the rear housing where the v-band is to connect the downpipe to the hot side.
I sent the seller a question. It states that this is a wider clamp for the turbine housing not for the exhaust. So, we'll see. It's actually a sweet clamp, so if it fits, I may get one seeing as how it's stainless. That'd be yummy and tons better looking than my nastified rusty one.
xanatos
63
Norcross, GA
Yeah, I hear that. I stopped by my dealer the other day looking for a vband and compressor nut and they only show the turbo assembly. Only part they said was separate was the dang gaskets. What kind of shite is that?
