Turbo blew up :(
mk3bandit
Jonathan D.
Feb 10, 2010
56
Denver, North Carolina, United States
We'll on the way home from work last night the turbo exploded. The car died as soon as the turbo went. I tried to start the car to move that car off the road. The car acted like it was out of gas. It's starts up but won't idle, but when I feather the gas it will run. I've pulled the codes but got no codes. Could it be something much more then the turbo. I've pulled my intercooler off and got the pieces out of it.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,236
Atlanta
Yeah, If you're lucky then you can just slap a replacement turbo on, and run it.
If you're unlucky, smaller bits of the compressor wheel made it through the intercooler and into your cylinders.
Backlash2032
1,823
Nebraska
If it sent bits through the compressor housing it would be an unmetered leak. Unlikely, but I've seen it.
Sent from my HTC6435LVW using Tapatalk
