So, I was reading some of the toyota tech articles about how the ECU controls fuel and what not. When I built my sentra, I removed all feedback from both O2 sensors. This caused the ECU to stay in open loop and made tuning so much easier since it prevented the ECU from attempting to change the tune by adjusting fuel trims over time. I could also tune for low load conditions at 16:1 which was perfectly safe and increased fuel economy. The transition to high load conditions was much smoother than the normal closed to open loop transition, no incredibly rich spikes. Also coming off throttle transition had no spikes. I did extensive datalogging with my LM-1 and have plenty of graphs that show how much more stable the AFR's were under differing conditions. All tuning was using SAFC2 and a 2 bar MAP sensor for the throttle input. My question is: has anyone done this on an OBDI ECU? If so, how did it go? I may do this on my supra after I install my SAFC2 and see how it goes.
