Alright.. i just bought an innovative lm1 wideband o2 sensor. I want to get a solid street tune down before i go to the dyno. Just looking for what you more experienced guys recommend me starting at as far as fuel pressure.. what you set for the high and low throttle settings on the safcII.. i was under the impression that the stock ecu will handle everything under WOT. If so i dont even need to mess with the low throttle air corrections correct?
Well here are all my mods..
87 turbo... stock rebuild about 15k miles ago
LIPP/BOSS TO4E 54
Aeromotive AFPR
Precision turbo 550 cc injectors
Lex afm
Apexi SAFCII
Greddy Profec B spec II
Lightweight alum. driveshaft
Spearco 1080cfm intercooler with 2.5" hardpipes
Apexi air Filter
Full 3" turboback exhaust to apexi can(no cats)
Egr Blocked off... Jtube block off
Walbro TT fuel pump
HKS BOV to atmosphere
Car is set to about 10psi right now... probably up the boost to around 12-15 not sure yet what i wanna run... anyone know what psi i would be running to achieve about 400 hp?
The wideband im getting has datalogging as well...
LIPP/BOSS TO4E 54
Aeromotive AFPR
Lex afm
Apexi SAFCII
Apexi air Filter
Walbro TT fuel pump
