building a 7mgte and have a couple questions
i will be running a factory turbo
3 inch downpipe
3 inch catback
test pipe
intercooler
aluminum radiator
255 fuel pump
aem wideband
fuel pressure regulator
1.9 mm mhg
arp studs
pulley set
mbc
i was wondering if i should use 550 or 660 cc injectors and i have heard a lot of debate on if i should run an safc2 or maft pro
any suggestions would be geatly apreciated thanks
3 inch downpipe
3 inch catback
test pipe
intercooler
aluminum radiator
255 fuel pump
aem wideband
1.9 mm mhg
arp studs
pulley set
mbc
