TTR springs are a rougher ride than expected....
rakkasan
Currahee!!
Fort Campbell, KY
Is there a comparable spring to the TTR spring that is a little smoother? I'd like to find a spring that is linear & drops the car between1" & 1.5" & offer a smooth ride. Is the only way to a smooth ride found in a progressive rate spring?
suggestions?
bwest
Drafting, not tailgating
May 18, 2005
502
HippieTown, CA
I have Tanabe's matched with Koni's. Coming from JIC c/o's its a whole different and smoother ride. If I was to do it again, I would probably go with bilsteins instead of Koni's - only because the Koni's are a pain to adjust and can only be truely matched on a shock dyno - where the bilstein's are bolt on and go.
my nickel.
