trying to get switch done but stuck.... Again :(
suprachick22
121
colorado
ok so i am trying to get my project done but i need some help again. here are two more pics EA2 as far as i know (sorry they are dark) can any one tell me of a good wiring site or what all i need to finish switiching the wiring over. this is plugged into the fuse box and looks like the lights also.
Also i have found out from reading that i need to move over the power steering lines but what all do i need to move? will the old lines and/or parts work?
mobes
Supras are never 'done'
Bozeman, MT
Have you seen this diagram?
http://www.1jz.com/tech/docs/wiring/EA21989.pdf
If you're not using the hydrofan that saves you some wiring there. Also you can just connect the body harness AC clutch wire by the battery to the 1JZ compressor clutch and skip the A/C wires in EA2. I ran mine through EA2 to tidy it up but that's just because I'm obsessive and it's not necessary.
As for the power steering, are you talking about wiring lines or fluid lines?
