I am installing a LIPP cast stainless turbo elbow with a 3 inch opening and a full 3 inch downpipe. The od of flange for the downpipe is about 1/2 " larger than the elbow's od. This leaves about 5/32" of the flange for the gasket sealing surface NOT including the flanged part of the piping that comes thru the downpipe mounting flange which is about 1/4" or so.
With that said is this enough of a sealing surface to hold up? The high flow cat's flange is about 1/4" also.
Next, the factory exhaust bracket that bolts to the tranny makes the downpipe up too close to the floorboard and too far outward. Should I modify this bracket or remove it altogether?
