Ok, I yanked my dead trans out. Then I tore it apart. Some bolt and internal bracket came loose, and ran around inside the trans until it came to a stop in the shift selector area that controls the forks. It put the shift fork shafts in a bind, and caused the shift linkage to pop out of the control area when I tried to make it go in gear. After I removed the crap that was broken, the trans goes in gears fine and when spun it engages the gears correctly now ????
Crazy stuff
Crazy stuff
