trans replace
turbo2
59
hawaii
is it hard to change a trans? the one i have now knocks like a mother :aigo: I already have an extra trans and my spec stage3 clutch kit :sarcasm: should be here in a couple hours:icon_razz :
Boosthpy
133
Idaho Falls
It is not too bad man. What trans do you have? Just make sure you take it slow and be organized. I beleive there is a write up on here somewhere.
Also make sure you have a bunch of extensions for the bell housing bolts. Its easiest to undo the trans mount and jack up the front of the motor and get the bolts from the back with the extensions. Also if it is the turbo trans make sure to pay close attention to how the throw out, pp etc goes together.
turbo2
59
hawaii
ya its knocking ,loud too. so far i iave empited the trans fluid,unbolted the shifter, and dissconnected all three electronic wires.:1zhelp: is there a right up with pick the tsrm kinda sucks in detial
Fletch124
2jz swapped!
Jul 17, 2005
1,282
Reno, Nevada
Tranny knocking? I assume its a R154(turbo 5-speed). I've never heard of a tranny knocking. You can easly trouble shoot it. If it knocks when you rev it and when your driving then its not your trans.
bountykilla0118
In Pursuit of 500rwhp
Jul 16, 2005
1,088
Atlanta GA
My w58 was shot and it had a loud tapping noise that sound like a rod knock. It got loud as my rpm's raised even when i was parked or moving. However the sound went away when i pressed the clutch pedal down......
turbo2
59
hawaii
^^^ its just like that!!!!! do u know what it is? i know its knot rod knok because it goes away at low rpms and it got worse when i droped the clutch at 2k rpms.
turbo2
59
hawaii
k ill just replace mine the privous owner had an extra one well its 10:00 hawaii time i better get started
turbo2
59
hawaii
well i hope its ^^^ that problem. im just having problems getting the drive shaft bolts of because of 3in piping. and its one pipe till the canster so i have to take off the whole thing. can i ,after i take off the exaust drop the trans with the driveshaft and just slide the trans foward?
bountykilla0118
Jul 16, 2005
1,088
Atlanta GA
If it sounds like a hammer knock the bottom end then i bet its the tranny i know the sound you are refering to when the bearings have gone bad but its no where close to same level of noise.
I had replaced both pilot bearing and throw out bearings twice ..... The ones i had on there had less that 15,000 miles because i upraded my clutch to a 6 puck and upgraded to a heavy duty pressure plate all for the w58.
I pulled the tranny i put brand new ones in after I heard the noise. I actually called bigaaron to let him hear the noise while I was driving and he was like "thats way more than simple grinding that tranny is shot"
bountykilla0118
Jul 16, 2005
1,088
Atlanta GA
-Drop the exhaust
-Drop the drive shaft center support (leave it connected to the diff)
-Drop the tranny support
-Lift the engine up from the harmonic balancer (you dont have too but it makes it easier to get the two top bolts)
-You have to take down the inspections covers on the tranny
-Unbolt the pressure plate from the flywheel (through the inspection covers)
-Unnolt the tranny and slave cylinder
Thats it
turbo2
59
hawaii
ok lastnight a friend and I stoped at 11:00 and the trans still isnt off:3d_frown: but all i ahve are the two or three bolts on top and the support :rant2:
