mazzer said:
yes its easy and i beleive the fluid capacity is 3 qts..give or take
i been doin some searchin lately for MT90 and the only place around that actually stocked it quit ordering it cause they said the prices went through the roof.turns out advanced carrys the water wetter and can special order the fluid so ill have mine in about a week to put it to the test.
Get it at summitracing.com
I just replaced the MT90 it in my 91T, and it actually makes a little more noise than it did before, and the gears actaully feel a little more notchy. I actually think its because I had some old MT90 in there, and it had somehow 'gotten used to it...' hows that for a technical term. I expect it to get back to great after a little while.
And it can actually be a kinda a bitch to get the fill plug off, you need a 24mm offset wrech, that was the only thing I could find that would get up there. Or a 15/16 SAE offset works too, same size.
watch the small aluminum washers, mine was all cocked up when I took it off, so I got another one, and toyota had a hard time finding me the friggin part.
FYI, you will need 4 quarts, it takes 3.2, assuming it all empties out... I used some of the forth, but i did it the "hard" way as some define it and used a suction pump to pump it into the fill bolt rather than removing the shifter
