Trans ABS Plug & Reverse lights
OneJArpus
2,798
OK seeing im gonig through my swap progress i'd like to try and figure out where these plugs are located on the body. I can't seem to find *hit on mine. So i'm trying to trace and possibly find out where they might go so i can wire up new connectors so my reverse lights work and my abs sensor for the trans is hooked up so that damn abs light can shut off.
Pics would help thanks
MarkIII4Me
Project OVERKILL!!!
Apr 10, 2005
1,250
Charleston, SC
Square plugs that run below intake manifold on engine harness. I know the rear speed sensor plug on an auto engine harness has 4 wires, where as the the sensor on the r154 only has 3 wires. The plugs are plug and play as long as the one on the tranny hasn't been cut off (like on mine :cry:). I still haven't gotten around to wiring it up since the colors are completely different. I understand that the 4th wire on the auto harness is for the ECT which is no longer used, but the remaining 3 wires are all different colors than those coming off the r154 speed sensor. If you get yours hooked up, I'd appreciate if you could PM me with what wires match match up from the r154 speed sensor to the auto wire harness.
***Crap, just realized you swapped in a 1J. Thought you were doing the common AT-MT swap, so just disregard my post as I'm referring to the 7M harness. However, it wouldn't surprise me if the 1J's was similar***
OneJArpus
2,798
ok cool, i'll keep an eye out for it. I have the harness upstairs so i'm going to go through it and see if i can find it. Does anyone know what the clip for the reverse lights look like? IIRC its two wires? maybe 1.
