tranny removal
dirtlord420
just here
Aug 1, 2005
371
tn
i need some advice on this one bolt. the one above the starter the bolts in to the block and the tranny. any one have any tricks how to get it out with out removing the intake?
mkiiSupraMan18
Needs a new username...
United States
Me personally, I woulda pulled the motor/trans together, because I used to have this habit of "forgetting" the top 2 trans bolts... Get ya those little stubby ratchet wrenches like they sell at Autozone/Advance, and then get a socket, a swivel and an extension and put it on the "back" *tranny side* of the bolt and just use it to hold the bolt while U take it out with the stubby. It's not hard at all. Or, slap a wrench on the back, get you some extensions and an air ratchet and "extend" out past the AC compressor and give'er hell. The wrench should find somewhere to stop itself. :icon_bigg
HTH
Those ratchet wrenches kick ass, just don't take any top trans bolts out with them, that SUCKS :biglaugh:
lagged
1991 1JZ
new rochelle
loosen the motor mounts and put your support (are you using a lift?) under the crank to angle the motor downwards. itll give you enough room to get a clear shot at those bolts with an extension.
dirtlord420
just here
Aug 1, 2005
371
tn
i dont have a lift i use a hugh front end loader witch works pretty good. yeah i should have just pulled the motor
C
cnewingham
Guest
I didnt put the top 2 bolts back in when I did mine and no problems at all.
lagged
1991 1JZ
new rochelle
smmmmarttttt....
well id say pulling the motor even without a lift is a waste of time. however i do understand that you might rather do that extra work than be stuck under the car in front of your house..ive been there and its no fun at all.
