Tranny Question!!!!!!!!! Help!!!!!
raymi
Slow is not an option !!
Dec 26, 2005
56
Puerto Rico
I bought a 1987 n/a but with a 7mgte turbo engine installed...($2,000) its an automatic. The original owner did the conversion but they left the original 4:30 rear end, will this help my auto tranny in the 1/4mile or hurt it ? I was told that it will help as long as I stick to the 1/4....I need info from you guys!!
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
your fine as long as it is a lsd as in tration wise
but as in power 4.30 rock but tration gets to be an issue when you go to bigger power
raymi
Dec 26, 2005
56
Puerto Rico
hey,thanks! but i should be ok if i stick to the factory torque converter right?
silvergsx623
WIPLSH & HWY KNG
Oct 16, 2005
498
Alabama
4.30 gears are good for the 1/4
it will hurt topend though.
the higher the number of the gear... the faster it will accelerate (with proper traction)
example 3.73's have more top end then 4.30's.. but 4.30's have more acceleration than 3.73's
raymi
Dec 26, 2005
56
Puerto Rico
Cool ! I can use the faster acceleration since I have an automatic plus down here in Puerto Rico its all about the 1/4 mile !!!!
NickSupra
179
tn
The 4.30s should suit you fine then. Make sure you have some good, sticky tires.
