tranny 1st and 2nd... help
stokeless
supra-man
michigan
in the last week or so, 1st and 2nd gear have been very tough to get into gear... the weird thing is if i put the car in neutral my car starts to rows but when i step on the clutch pedal the car stops... i can hear a thump when i step and release the clutch pedal... what do you think is wrong. car drives and runs but very hard to get into 1st and 2nd gear.
i replace the clutch 8mos ago.. new pp, disc and throw-out bearing. i checked the master cyn and fluid looks good.
any ideas...
supra90turbo
shaeff is FTMFW!
32
MA, 01440
Bent shift fork making the transmission want to engage a gear regardless?
sounds like it's putting pressure on a synchro when you're in neutral...
::woot 4,000th post!::
stokeless
supra-man
michigan
no grind... once it's in gear it's fine. all other gears goes in normal, just 1st and 2nd. i have to really force it in but again no grinds.
