trann or clutch problem?
Boostin4Life
Boost addict
Jan 7, 2006
47
Oklahoma
So as im driving home while i shift i notice its gettin harder and harder to get it in gear. I then stop at a light and when i was to push it in first it would not go in for the life of me i tried every gear then i did the old fashin blip the throttle and shift at the right rpms. The clutch was still engaginb becuase i could take off once i blipped the throttle to get it in gear so i did this all the way home and now i don't know whats wrong? any ideas
Godspeed
88 supra turbo 5spd
May 13, 2005
1,119
Asheville n.c.
may be the throw out bearing i know when i had my clutch installed they used some crappy t.o.b. and i have to blip the throttle in mine to go in reverse.
mkiiSupraMan18
Needs a new username...
United States
I'd check the clutch Master Cylinder for fluid.... chances are it's leaking and you'll need a new slave or MC. my 82 Does this and I still gotta put my MC in. it's not hard it's just doing it that I'm not looking forward to.
^ Try shifting into 1st before going to reverse. It'll make life easier most of the time.
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
I'd put money on a leaky master and / or slave cylinder.
mkiiSupraMan18
United States
In the shop? All you needed to change it was a 12mm socket, a ratchet, a 10mm wrench, some rags, and maybe a short extension. And a new MC, like $50, and some fluid $3 or so.
Boostin4Life
Boost addict
Jan 7, 2006
47
Oklahoma
well i started it up this morning and it sounds like a knockin noise as if the clutch or flywheel was hitting the transmission but when the clutch pedal was pushed in it went away so we have narrow it down to the t.o.b or the clutch was not torqued down to the specific torque.
