Okay, since the day I bought the car (about 5 months ago) it has had a terribly annoying misfire only during light throttle and only after the car is completely warmed up (on cold days sometimes the car won't get hot enough and will run flawlessly all day). The car always idles great, but when it gets hot you can feel a very slight misfire in the idle. Car never overheats, although my coolant light is always on.
When I accelerate at full throttle, the car pulls hard and doesn't smoke and pulls all the way to redline perfectly.
When I let off the throttle and the engine decelerates, the exhaust gurgles and backfires.
Also something that probably isn't related, my BOV doesn't do anything until the car is almost warmed up. This has stayed true with two different BOVs.
So far I have:
Changed plugs and wires
Replaced every vacuum hose and rubber hose that I could find with silicone
retightened all intercooler pipe connections
Set TPS
I'm going to set the timing on my next day off, does anybody have other suggestions of things to check?
Car mods:
3inch exhaust with ractive muffler, stock turbo elbow
cone filter on stock accordian tube
HKS BOV
So far I have:
Set TPS
Car mods:
HKS BOV
