Ok so Im a little confused. Im wiring my Q45 TPS into the stock wiring based on X-Mans wiring. HOWEVER... my problem is for some reason i have voltage (with the key in the ON position) coming from the BROWN wire. Which is E2 which i understand to be a ground. Rather then the Blue with Red stripe wire which is supposed to be the 5V supplier. Which im getting NOTHING from.
How is this happening? How do i go about tracking down how to fix it etc? Right now with the correct wiring of the Q45 connectors (based on Xmans wrietup) im pulling codes still with the TPS. I feel as though the voltage coming from the wrong color wire may have something to do with it.
Any input on this would be greatly appreciated. Thanks
