TPS? COUPLE questions supra newb
MK3Supraman
67
olathe,ks
bought 87 supra turbo 5 speed targa no rust bright yellow for 2k fresh tigerjap swap 40k on motor
i get it home and notice the wat i think the tps had the sensor unplugged. so when i plugged it in it started to idle rev from 1k to 500 an throws code random at 500 then back up
next
notice something drippin on my downpipe after i stop the car but i check my oil and its still at full any ideas? not coolant
also
oil pressure only hittin like 38 psi at 3k(wont go higher) gauge broke?
jdub
Feb 10, 2006
10,730
Valley of the Sun
What specific ECU code?
Sure it's not coolant? There's a couple coolant hoses near that area. You could add some UV dye to your oil and check with a black light in a couple days.
Your oil pressure is in spec:
http://www.cygnusx1.net/supra/Library/TSRM/MK3/manual.aspx?Section=LU&P=4
It is on the low side though...might want to check with a mechanical gauge at the sensor location. The fitting is 1/8" BSPT.
MK3Supraman
67
olathe,ks
its not coolant its oily like ps or oil which probably relates to low oil presusure??wats around that area that has oil?
also code just flashes at 500 then disappears in a second
anybody with the tps?
MK3Supraman
67
olathe,ks
from wat i got codes were
14
and
25
so 14 is that like plug wires an sparks?
and 25 thats a lot of stuff to check but i get horrible gas mileage so oxygen sensor?
also car is BONE STOCK so idk runnin lean
but fuel pressure would make sense since i have to try twice to start it
dumbo
1,911
Albera, Too Far North
I would try the external igniter ground(search it) its cheap and easy. Not sure if it will do anything though.
Also check your TPS per TSRM.
I'm certain it has nothing to do with your spark plug wires.
BTW...Nice Ride:cool:
Jokervrs
57
California
Very nice looking car. I blew the headgasket to hell on my 87 na and i was looking to get a new Tigerjapanese engine. Hows that engine holding up for you?
MK3Supraman
67
olathe,ks
o man runs like a dream havnt had a problem yet
guy got it and drove 20k on it and ive had it for 1.5k
runs so good no problem lots of power
only thing is valve cover gasket drippin on my down pipe lol every once in a while
thanks guys means a lot love this car i finally got one after tryin for 6 years lol finally let go of all my hondas :biglaugh:
got the ride for 2k flat :sarcasm:
