supradan22 said:What damage could be done just pulling it in neutral?
NATAN666 said:never tow a rwd car from the front. even if you disconnect the driveshaft theres undue wear on the differential.
Figit090 said:Towing with front on the ground: reccomends using towing dolly and having the key in the ACC position as the steering lock isn't strong enough to hold the front wheels straight while in tow.
Joel W. said:A regular tow truck can also tow it in the wheel lift and toss a set of dollies under the other wheels.. Sometimes this is cheaper than a flatbed tow truck.
If the car will idle, you can tow an auto in nuetral with no fears, but yes without fluid pumping through the tranny it can cause damaged after a few miles..
