Torque spec on main caps and BC rod caps..
whitemike
1,164
Winter Park, Florida, United States
Hey guys,
Quick question if you wouldn't mind.
I need the torque spec for a 7M on the main caps, and also the rod caps. The twist is that I have BC rods and I'm not sure if they require a different tq than stock or what.
Any help is appreciated.
Thanks,
-Mike
arizzle
Lov'in the boost.
Nov 1, 2006
996
burnaby, BC
if the mains are also ARP they will come with a torque sheet. also as for the rods call BC, to see what its suppose to be at cause im sure they came with ARP just eagles.
suprarich
Guest
Nov 9, 2005
2,187
ohio
The spec for the arp in a bc rod is special to the rod and not a ARP spec at all. You need to call BC for the spec. I would venture to say it is 43 ft lbs with moly, but you need to call BC to be certain.
