Torque help!
supratoy_2009
San Antonio, Texas
I just put together my 7MGE now i have put arp studs! Whats the correct torque for this set up? I have read that using the torque specs from the manual was not a good idea! I would appreciate any suggestions. thanks
M_31_07
211
San Jose, CA
Did you use a stock replacement head gasket? if so 75 lbs should be good enough. If you replaced it with a metal head gasket anywhere from 80-90 lbs.
7M-KDL
Seeking high numbers
hey Ian do you happen to know what ARP recommends for torque on the main studs? i had my motor built at a shop and they installed them but i want to make sure they are all torqued right. but since the shop installed them i do not have the paperwork but i do know that they used the supplied moly lube.
BlackDynamite
KTHXBIA
Feb 24, 2007
714
Oregon
Yeah, i always buy new arp head bolts for every rebuild. ;]
But i never knew that stock headbolts were NOT TTY. Good to know. THANKS IJ! :D
