torque converter
JesseH
1,153
Englewood, Ohio, United States
ok, so I decided to take my chances and order one of those shifting kits for the auto from awshifting.com. Just wanted to know when the best time to turn on/ use the torque converter. I'll let everyone know how it goes once I get it installed.
I think Tookwik knows alot about automatic transmissions. Hopefully he will see this. I may bring it to his attention, since you need help.
tookwik4u89
Red T-shirt
Apr 6, 2005
2,008
Rockford, IL
I wish I was better help, that's just too much controls for me. I think you basically would want it in lock up once you're up to speed, low load(overdrive). You want to take off and accel with it off or you defeat the purpose of having a stall. I bet if you get ahold of Jdub, he can give you a better answer. I used a similar setup used by Toyota for testing, I liked the way it shifted on its own better, plus I wanted more consistency because I was bracket racing.
This is all the info I found on their website:
What does the torque convertor lock do?
When you lock up the torque convertor it takes the "slip" out of the transmission making it more efficient and run cooler. The factory computer will lock it up under medium to light throttle in third and fourth gears, basically to gain efficiency when cruising on the highway. Some people use it offroad for extra compression braking, and although I can't recommend that because it's not designed for it and will likely reduce the life of your torque convertor, many people do it and I've never heard of a failure.
jdub
Feb 10, 2006
10,730
Valley of the Sun
Here's a little "light reading" for ya
Toyota ECT:
http://www.autoshop101.com/forms/h16.pdf
http://www.autoshop101.com/forms/h17.pdf
Here's the shift schedule in the TRSM:
http://www.cygnusx1.net/supra/Library/TSRM/MK3/manual.aspx?Section=AT&Page=40
Inside a torque converter:
http://www.protorque.com/techi/ti_al.htm
Working with a tranny computer is an intricate thing...if you adjust your shift schedule higher, be careful and do it in small increments. Be very careful with lock-up...you are mechanically coupling the engine to the drive train to increase efficiency...i.e. max power to the wheels for a given gear in a 1:1 ratio. The downside to early or lower gear lock-up is it will cause wear to the lock-up clutch faster.
