Was just reading an article. Some may find it interesting...
"During engine assembly or after intensive internal maintenance, it’s common practice to replace the factory head bolts. Head bolts, also known as torque-to-yield bolts, are designed as one-time use bolts and will permanently stretch once installed. OEM head bolts are designed to provide both a twisting force and a vertical clamping force, which means that when the combustion chamber begins to accumulate load, the bolt will both stretch and twist. Because the bolt has to react to two different forces simultaneously, its capacity to secure the head is slightly reduced and it forms a less reliable seal in high-powered engines.
By contrast, a head stud can be tightened into place without any direct clamping force applied through the tightening, as a nut is torqued into place against the stud. The nut torque provides the clamping force, rather than the torque of the fastener itself, and the rotational force is avoided entirely as the pressure from the nut will make it stretch only along the vertical axis without a concurrent twisting load. The result is a more evenly distributed and accurate torque load compared to that of the head bolt, and reduces the chance of head gasket failure.
From a manufacturing perspective, in order for a head bolt to be cost effective, it is often made from low-grade steel with a class rating of 10.9 and a typical tensile strength of 150,000 psiabout the same tensile strength as an SAE Grade 8 bolt available from your local hardware store. Aftermarket performance head stud companies like ARP manufacture fasteners from at least six different steel alloys ranging from 8740 chrome-moly to chromium-cobalt-nickel alloys and titanium, all using a cold forging process to ensure molecular integrity as well as being heat treated prior to thread rolling and machining to harden the metal. This patented metallurgical process enables ARP to manufacture a head stud with a tensile strength ranging from 180,000 to 270,000 psi, with strength and fatigue properties far superior to OEM head bolts."
