too soon for hg retorque
corewitz
53
Omaha NE
hey everyone i just got my motor started on sunday and i have had it heat cycled about four times, from sunday through wednesday i drove it to operating temp and cooled it down overnight, the car has about 5 miles on it so far. is it too early for a retorque with arp studs?
drbowser3
The Doc is in...
Jan 17, 2006
215
Tampa,FL
What torque did you go to, I have 3000 miles on my MHG with ARP studs. I haven't re-torqued them and dont plan on it, and thats running with 17psi. With studs I dont see the need. There are about 7 7Ms running in the area with arp studs that havent been retorqued, most with over 10,000 miles on them. But if you want too, I woul go a bit longer.
drbowser3
The Doc is in...
Jan 17, 2006
215
Tampa,FL
90 ft/lbs, I torque the sequence @ 60 ft/lbs, then thru the sequence again at 90, loosen till they spin freely, then run them back to 90.
jdub
Feb 10, 2006
10,730
Valley of the Sun
The ARP spec for studs is 81 ft/lbs using moly for lube...105 ft/lbs using motor oil. You DO NOT want to over torque.
corewitz
53
Omaha NE
i got brand new arp studs, installed them and torqued to 80 pounds with moly lube, and have about 4 heat cycles with a cometic hg
shaeff
Kurt is FTMFW x2!!!!
10
Around
on new hardware, it is necessary to re-torque because even ARP studs will stretch to a point. after they've been heat cycled and re-torqued, they're not supposed to have to be re-torqued ever again, but why chance it?
it took me a beer and an hour and a half to re-torque... (while carrying out a full conversation with my friend, who happened to stop by)
-shaeff
